Posts About Datastream® CMMS
What is the maximum number of characters an Mp2 barcode scanner will read?|
Customers implementing barcode for Mp2 often wonder what the maximum number of characters a barcode scanner will read.
There is no definite number of maximum characters that scanners will read. Different characters will have different barcode lengths, for example, 111 will have a shorter barcode label than BP2. When configuring your labels, experiment with different font sizes and styles. Print them out on a sheet of paper (to avoid wasting labels) and test the scanner for readability. Be sure to document your settings. Best of luck with your barcode implementation! Jennifer Ohl |
Hello Jennifer,
you are right regarding the theoretical limit. But depending on the amount place on your labels there is a (real small) limit when using 1D barcodes. Labels with a width of 2-3 inches can take approx. 10-15 chars with barcode 39. Using smaller or denser barcodes brings up faults in a short period of time due to dirty labels. Using BC128 makes it worse as this adds additional checksum "chars" in the barcode. If you really want to place a lot of information (but why ?) on these labels you better use 2D barcodes. But also here we see limits (2000+ chars). And also here we are faced with the dirt issue again. I have never seen a good implementation of barcodes that required more than an ID as barcodes and some human readable text (typically the ID and the description). |
