Here is a question I am asked often-
What is the difference between the short and long forms on the work order?
The short form does not print comments on the work order, the long form does.
If you are using the work request module or WebLink, you may want to print work orders with the long form, since they may have comments that were entered via the work request table or WebLink.
Jennifer Ohl
Midwest Software Specialists, Inc.
Chicago, IL
773-844-4831
www.midwestsoft.com
Posts: 14 | Location: Chicago, IL | Registered: 14 November 2005Reply With QuoteEdit or Delete MessageReport This Post
Short form does not give you barcodes to each equipment. Where the long syle gives you barcodes for each equipment listed. Very helpfull when you are tracking the parts used to each equipment. When you scan out parts using the scan gun it asks for the Work Order then Equipment barcode. If you print short style you don't get the Equipment barcodes. While the short will save you some paper if you don't use a scan gun to check out parts to them.
Jason Millington
Jason Millington
Asset Management II, SMRSC
2004 Innovation Award Winner,
SMRSC Safety Committee member
H-E-B Grocery Company
512-753-5828 (75828)
512-753-5890 (fax)
millington.jason@heb.com
Life is not measured in years, but with knowledge and experience you have achieved.- - - -Jason Millington
Posts: 3 | Location: San Marcos, Texas | Registered: 28 March 2007Reply With QuoteEdit or Delete MessageReport This Post
As you say, the long form has a lot of data that is not required, but shows work order comments.
Crystal Reports 5.0 can be used to edit the Work orders. 5.0 is an obsolete version of Crystal Reports, off the market since the mid '90s.
Many clients have asked me to edit their long form work order using my copy of Crystal 5.0, making it shorter than the "short form" work order, improving readabliity and reducing confusion.
If you are interested I can send samples.
Donal
Donal Fleming
Fleming Technical, Inc
http://www.flemingtechnical.com
Posts: 26 | Location: Atlanta, Ga | Registered: 13 May 2005Reply With QuoteEdit or Delete MessageReport This Post
