How to list MN/MO by Object Class|
IW28 and IW38 can do that?
Panuphan B. Maintenance Information Manager PTT Aromatics and Refining Public Company Limited |
What is MN/MO?
Maintenance Notifications? Maintenance Orders? |
Minnesota/Missouri?
Danny |
Yes, it is. Danny I think you may be joker than reliability engineer Panuphan B. Maintenance Information Manager PTT Aromatics and Refining Public Company Limited |
From list editing select the object and find Notification.Same hold true for Order.
In equipment master have assigned object class for example all pump tag assigned object class PUMP
When we want to know in month have failure occured of PUMP, I list from Notification search by Object Class.....where of field Object class in List editing screen? Panuphan B. Maintenance Information Manager PTT Aromatics and Refining Public Company Limited |
What ever is defined in catalogue profile i.e. for ex.Object, Damage codee and reason.I mean what ever standard is followed for catlogue.The same is searched in List Editing mode(4.6.
If I am understanding your question correctly it can be done by running a list editing transaction for the technical objects, for example IH06 for functional locations or IH08 for Equipment.
In the classification section of the selection screen use Class type, Class and valuation to eneter your object class critieria, in your case for PUMPS. Execute this and you now have a list of all your pumps. Then from the menu select Environment - Orders or Environment - Notifications to go get the list you are looking for. |
Yes! I've get solution from you. Thank you Panuphan B. Maintenance Information Manager PTT Aromatics and Refining Public Company Limited |
You can also use MCI8 cost analysis, then drill down by hirearchy. Sellect Equipment or Functional location class. Depending on your class hirearchy you can drill in to general pumps/centrifugal pumps etc.
We have a user defined analysis that takes MCI8 and allows drill down to the order level. The advantage in using the SAP analysis is you see period costs and not total order costs. If the order carries over multiple periods your cost numbers will not match Finance. class_drill_down.png (20 Kb, 9 downloads) class drilldown mci8 |
