David I would ask you, your equipment set deactivate or deletion flag? If not, I think you can create notification for a past. SAP just tell the information dialog box to alert you.
Panuphan Boonsirirat Lead Maintenance Planner PTT Aromatics and Refining Public Company Limited
| Posts: 323 | Location: Thailand | Registered: 22 April 2004 |
IP
In face, you did the dismantle equipment from FL and would to record some task of equipment refer to FL. I think it impossible to do that. So, I would like to ask you why you want to report it and another question, is the task in the past or present after you dismantle?
IP
Sure, I knew that you need to analysis equipment failure. - Is equipment you dismantled have install to new FL? - When you analyze failure from a past, do you use FL information or which level do you analyze? I think you need only equipment level for failure analysis. So, not necessary to use FL for your method except you analyze where location or FL level.
IP
quote: Originally posted by David - Australia: I am wishing to make a record of past events - findings from failure analysis on the equipment.
its going to be an ABAP query, but if you enabled the change documents in PM, you can track the history of the installation FLoc A to None to Floc B) of the equipment. from that, you can link to QMEL table for your notification history.
| Posts: 8 | Location: Manila | Registered: 01 July 2008 |
IP
