I am working in order to implement PM modulo in SAP. Is posible add failure codes into WO?
Posts: 2 | Location: pto san martin | Registered: 06 October 2005Reply With QuoteEdit or Delete MessageReport This Post
Yes
I believe SAP keeps history using failure codes in the notification, not the work order. The notification can be attached to the work order.
Posts: 124 | Location: Melbourne, Australia | Registered: 05 May 2004Reply With QuoteEdit or Delete MessageReport This Post
You may concern about the failure code design becoz it's important for failure analysis such as RCFA or FMEA
Now! I doing review the existing failure code in SAP to relate about FMEA method.
Panuphan B.
My answer was yes above because we have a notification and a work order for any jobs in SAP PM. The item record is in the notification.
What standards do you refer to for your review? How do we ensure that the data collected are useful for RCFA & FMEA in view of the Resniskoff's argument ie a lot of data but not useful for vital actuarial analysis?
I know standard code refer to ISO 14224 but I think design failure code different depending on equipment, Normally I use from historical failure in the past
Panuphan B.
O ok you mean "DESIGN" failure codes. I'm not sure about this. Any examples?
This example for only Pump, I will do it every equipment group later
I'm not sure this design are well for analysis
Someone can suggest for me.
Panuphan B.
A design failure code
Wrong Layout : Equipment's maintenance access door has only six inches of clerance from nearest wall. Mad
Darth Eugene Vader
Many Thanks a lot! You were help me a lot. I will go on and i tell us my experience.
Aromatic thailands are in the correct way about faul cade.
