Maintenance and Reliability
Root Cause Analysis
Why submersible motor mechanical seal failed?|
Anybody has experienced similar failures before?
The mech seal is John Crane Type 1A which is for general service, single spring, elastomeric bellows seal. http://maintenanceforums.com/eve/forums/a/tpc/f/119103451/m/9001053162 |
Errr - submersible MOTOR seal failed?
Can you tell us a bit more please? What is this motor doing submerged, driving a pump or something? If so, what is it pumping? Where did the big pile of sludge come from? What is the heavily scoured disc thing? |
Cheddar
I embed my answers under your questions as follows: Can you tell us a bit more please? - There 2 submersible seawater lift pumpsets, A & B. The motor is of wet-winding type and being cooled by an external cooling water from the overhead tank on the platform. What is this motor doing submerged, driving a pump or something? If so, what is it pumping? - Yes, the motor is driving a pump to lift seawater from sea onto offshore platform. Where did the big pile of sludge come from? - The pile is suspected by the OEM workshop to be the 2 motor Graflon bearing bush materials after being completely obliterated. What is the heavily scoured disc thing? - The first photo is the ceramic mech seal stationary face. The second photo is the carbon rotating face. This message has been edited. Last edited by: Josh, |
Here is the picture of the submersible motor with its mech seal and journal bearings:
http://maintenanceforums.com/eve/forums/a/ga/ul/6351052...ubmersible_motor.bmp |
Can motor disgnostics replace vibration monitoring for submersible pumpsets?
The guys from Baker claim that current and instantaneous torque measuring is a good alternative to vibration monitoring when the machine is not easily accessible for vib monitoring.
Any guide or article on that Pete?
http://www.bakerinst.com/BakerWeb/PDF_Files/Modern_Appr...hanical_Failures.pdf
http://www.bakerinst.com/BakerWeb/PDF_Files/Instantaneo...Maintenance_Tool.pdf http://www.bakerinst.com/BakerWeb/PDF_Files/Comparison_...antaneous_Torque.pdf Possibly a few more in the list here: http://www.bakerinst.com/BakerWeb/Support/Case_Studies.html |
Root Cause Analysis
