Dear sir,
sir now i working in plant reliability, and reability have RCA and RBI.
where;
RCAsed for saves live
RBI used for Optimized & cost effective inspection strategy,
for handle above have one center (RCM ) used for improve technical integrity.
Question:
1. where step the first i will take to effective reliability ( Utilities and offsite plant )?
2. Pls give me about structure or flowchart reliability.
because for next week i want presentation about reliability.
Thank
regards
efendi
Wink
Posts: 1 | Location: Saudi arabia | Registered: 11 August 2008Reply With QuoteEdit or Delete MessageReport This Post
That is a big scope of work
you can do a structure approach starting with criticality analysis for the whole plant or can apply a fast track approach and go after the big problem areas measured in cost, downtime,
RCA is not just for saving lives its a process to analyse problems and incidents including reliabiliy issues and failures
RBI is for static equipment and vessels
RCM is for building startegies based in desired function
Hope that helps - buts its a big topic and without knowing plant and your problems is diffciult to answer
Posts: 32 | Location: England | Registered: 25 November 2005Reply With QuoteEdit or Delete MessageReport This Post
May I give some comments about Reliability tasks for improvement.
First go to bad actors that give impact to operation/production with higher opportunity loss
Second set immediate action for correcting them as survival stretegy
Third, as you said RCA might be useful to show us the root of problem and correct them as long term prevention but should start with the simply things without spending money too much
Fouth, set up 3 year plan for reliability improvement with KPI ' s measurement.
prasong
Posts: 3 | Location: I2,Mabtaphut Industrial estate,Muang,Rayong | Registered: 18 December 2006Reply With QuoteEdit or Delete MessageReport This Post
