Maintenance and Reliability
Bearing Conversion Charts - AFBMA to SKF|
I have seen this chart somewhere on this forum but I could not convert AFBMA number completely to SKF number.
I want to convert AFBMA Number 50BC03JP30X28 to equivalent SKF number.From the chart I referred, last two digit numbers could not be converted. Can someone help. |
I had no luck with my conversion charts on that one.
You might try http://www.skfusa.com At one time that had an on-line afbma converter page. As you probably know, those tail-digits are not relevant if your objective is vib monitoring. But may be important when ordering replacement bearings. You can always ask your bearing distributor to convert it also. |
AFBMA 50BC03JP30X28 is equivalent to
50BC03 = SKF 6310, J = Pressed Steel Cage, P = One Shield, 3 = C3 (Looser than Normal) Radial Clearance/Preload, 0 = Normal, ABEC1, ISO P7 Tolerance Class X28 = S1 (Heat Stabalized to 200 degC Special Feature This is from SKF Bearing Handbook For Electric Motors, SKF Book # 140-430, June 2000 |
I looked in that publication and missed it.
Just to follow a little further, the SKF identification would be 6310-Z-J-C3-S1 6310 = 50BC03 Z single shielded J = pressed steel cage C3 looser than normal internal clearance S1 - Heat Stabilized to 200C Tolerance class 0 is standard and does not require a suffix for SKF bearings. One thing I can't remember - do single-shielded bearings come pregreased or only doubleshielded bearings? |
Thank You so mauch Jamie & Elctricpete. Could you please send this conversion chart. I need to convert 10 such bearing numbers to find SKF equivalent.
A tool that would be handy for you is the Bearing Expert program which contains over 1 Million Bearings. Can cross reference by part number, dimensions, bearing type, manufacturer and AFBMA number. Also contains over 200,000 bearings fault frequencies.
http://www.reliabilitydirect.com/vibrationmeterproducts/vibfrequency.htm |
Hello All,
SKF offer a conversion guide at http://www.skf.com and http://www.aptitudexchange.com If any of you need to convert bearing designations to SKF, I will gladly have them converted for you just e-mail me your lists for conversion. Ahmed H. Danish, CMRP Reliability Consultant Middle East GE Infra, Energy |
Dear Ahmed,
Thanks for your support. Could you please send your E mail address on alpeshp@essar.com |
