dax
I am having a atlas copco ZR #355 air compressor and commissioned recently.High vibration observed in HP stage female rotor (23 mm/sec pk pk)and g value of 10 gSe.When it is loaded a higher vibration obsrved upto 7.3 kg/cm2.Above this pressure the vibration stablises upto 15mm/sec pk pk.Spectrum shows peak at 40025 CPM and 80035CPM.Details attached.Can help??
Posts: 18 | Location: delhi | Registered: 05 April 2008Reply With QuoteEdit or Delete MessageReport This Post
Dax,
It looks like HP pressure pulsation. The discharge system (silancer) is in resonance. It needs to be re-designed. Is the silancer installed directly on discharge flange?
Posts: 104 | Location: Baytown, TX | Registered: 17 March 2006Reply With QuoteEdit or Delete MessageReport This Post
dax
THANX ALEX,
yeah the silencer is fitted after the HP stage and then itis connected to aftercooler and dicharge(see attachment).But this is a standard desin for atlas copco.The vibration is max in female rotor.I was thinking Lobe mesh frequency since 4Xmale rotor frequency comes in spectrum.Anyway if it GPF then wat are the reasons
Hi dax
Sorry I can't offer any help on this occasion, I have one question though in doc1 it would seem that to access the compressor's technical details you just use the drop down box.(top right of page) Is this correct what program is this?
I need the details for a ZR250 and GA250W compressors but cannot get this information, any help or assistance would be greatly appreciated
Mike.
Posts: 79 | Location: uk | Registered: 19 July 2004Reply With QuoteEdit or Delete MessageReport This Post
dax
i dint use any drop down...jst copy it
dax thanks for the reply by the way where did you copy it from?
