Hi all,
Just wanted to share that due to the magnetic mounts I use to attach accelerometers, the airline wouldn't check my data collector case and I missed a flight.
Apparently is an airplane regulation they are strictly enforcing now. Something to consider for future airtravel with data collectors.
Yet another reason for stud mounting Wink
Elias
Posts: 70 | Location: Vancouver | Registered: 26 June 2007Reply With QuoteEdit or Delete MessageReport This Post
Elias,
Was the only complaint the magnets? Has anyone else had this problem? Thanks for the heads up.
Posts: 157 | Location: Trane - Nashville, TN | Registered: 20 February 2005Reply With QuoteEdit or Delete MessageReport This Post
The only complaint was related to the magnets. TSA regulations limit the magnetic fields to 2.9 miliGauss. I couldn't prove if my magnet was above or below that. I should check with a gussimeter, but i'm sure its above that.
Their rule of thumb is to limit magnets to the size of a finger tip. The little magnet that comes with datapacs should be allowed by that standard.
I will look more into this, as I have to travel with my data collector often.
Elias
I travel with magnets some and have never had a problem. In fact, I just flew to Denver with six magnets significantly larger than a fingertip. Most of my travel is within the US and Puerto Rico though. I noticed your location is Vancouver. Was this a Canadian thing, or does the rule apply to other countries?
Michael Titone
Posts: 59 | Location: Southeast USA | Registered: 20 February 2005Reply With QuoteEdit or Delete MessageReport This Post
For just this reason, we at BN have had six SuperMags tested in a metal box and have certs that they meet the requirement. This all came about from someone being flagged 10+ years ago (even before TSA).
We ship to the site if we need large quantities of magnets.
John from PA
Elias,
Maybe you should just respond in a very arrogant tone that any fool would know that these magnets are less than 2.9 milliGauss. Wink
mGauss seems awfully small.
Bill
Bill.Foiles@bp.com
If you had a metal plate in your head, you'd be worried too! But how on earth would the magnets effect air - basically my last venture was airheads. Four gave me a ration - basically unable to speak english and appeared to be TCN's for USA.
If your magnets are 2-rail magnets, you might lower the 'field' by attaching them to each other (rail to rail) instead of the typical flatwasher. This might 'cancel' some of the magnetic field.
