IRD 885 OPERATING SYSTEM|
Hello everybody:
I have an IRD 885 and I can´t to load it the OP SYS. In the screen only appears the following information: A>echo off MS-DOS (R) is a registered trademark of Microsoft COM1: 9600,n,8,1,- Bad command or file name C>_ If a try to load te OP SYS by executing "LOAD885", several "*" starts to appear but suddenly they stop and only one "-" remains running in the screen and the OP SYS doesn´t load even if I wait for 20 minutes or more. Someone would like to help me in this regard? I really will appreciate your valuable help. regards. |
The communications setup must match:
Com 1 9600 baud non-parity 8 bit 1 Make sure they are the same and re-try. Cordially, Sam |
Sam,
Thank you for the help. I already checked the parameters that you mention and they are correct, but the problem remains. Could you have another solution? thanks in advance. |
