I have to agree with Don. It sounds like soft foot to me. Could be you have a foot that is not in the same plane as the others or is not parallel with the base. Try taking a mag base dial indicator and check each foot for movement.I've seen soft foot where the shim pack did not get loose when all the bolts were loosened. Required step shimming because of non parallel to base foot. Regards,
Roy Gariepy Maintenance Tech Cross Generating Station Cross, SC
| Posts: 182 | Location: Cross, SC | Registered: 02 December 2004 |    |
Soft foot is just side effect, real problem is resonance. So by loosing one foot, you are changing stiffness, physical properties of a structure. You should bamp it and try to find what is natural freq or excitation of a structural resonance. Change stiffness or speed. Personally I don't think it is beg deal leave one foot loose, just remove bolt, because soon or later one of our friends operators will tight it up. Good luck. Dragan
Remember, "No whitewater or powder in BC"
| Posts: 19 | Location: BC, Canada | Registered: 07 March 2005 |    |
quote: Originally posted by DragonT: Soft foot is just side effect, real problem is resonance. So by loosing one foot, you are changing stiffness, physical properties of a structure.
Why is it resonance? A soft foot can cause a distortion of the motor itself resulting in a variable gap which can generate high rotor bar pass or high 2x line and have nothing to do with resonance.
| Posts: 450 | Location: Great White North | Registered: 21 February 2005 |    |
quote: Originally posted by rgf: We have a condition on a overhung fan where if we leave one of the motor mounting bolts loose the vibration is considerably reduced. Does anyone know of any reference studies or case histories that would relate to this situation. Our structural guys have nightmares over loose bolts but we (vibe guys) see it as a solution (short term) to a high vibration condition. Any experiences or input ?
I didn't make my self very clear in the original posting. I know it is a soft foot condition. What I was looking for is any case histories where the condition was not corrected and the machine was returned to service. The machine in question is a seismic qualified Cat 1 fan in nuclear power service. We are doing an evaluation on why it's perferable to run with 1 of 4 bolts loose with low vibes vice shimming the bolt and running with high vibes. rgf
| Posts: 33 | Location: Syracuse, New york | Registered: 28 April 2004 |    |
quote: Originally posted by rgf:What I was looking for is any case histories where the condition was not corrected and the machine was returned to service. The machine in question is a seismic qualified Cat 1 fan in nuclear power service. We are doing an evaluation on why it's perferable to run with 1 of 4 bolts loose with low vibes vice shimming the bolt and running with high vibes.rgf
Well, the case history would have to be looking at the reason the facility approves of this type of practice. I'm in a paper making facility and we would never allow this condition, we would properly shim the motor to eliminate soft foot and use all four hold down bolts. I'm sure the motor designer has given us four hold downs and the right bolt size to overcome the torque generated at maximum HP. The soft foot check is the first step in our alignment procedure and we use tapered shims if necessary to get it out. We have even taken the motor, where practical, and machined the feet.
RGF, Man I'm surprized they are even condisering continued operation under these conditions. A company call Ludeca sell a plastic shim that you can insert under the foot that has the soft foot and then torque. It will then harden. They are awesome, I have used them alot due to the age and condition of the foundations at the Mill I used to work at. If angular soft foot is truely your problem these shims will fix it. Kelly
Live Free Or Die
| Posts: 69 | Location: Holly Hill SC | Registered: 23 February 2005 |    |
