Peel-off vs sof shoe shims|
Hi guys, What is your experience in dealing with angle/sprung soft foot and these types of shims.Our new Pump Eng.appears to be strongly against the Sof Shoe Shims. From what I heard, they are a good quick fix. Thanks, Manny K
By the way, his choice are some type of Stainless Steel "peel-off" shims. Thanks, Manny K
We have installed Precisionbrand "Sof' Shoe" plastic shims on 6 or 7 motors over a period of about 7 years.
In all cases these were 2-pole motors with 2*LF vibration which was demonstrated to be foot-related (changed substantially during foot loosening) and which we couldn't get rid of any other way. In some cases it took about 2 weeks to see full decrease in vibration. In all cases the vibration is substantially reduced and hasn't come back. We also have no shifting of alignment that we have detected. |
Consideration is, IMHO: Soft Shoe works great but with limitations of time restraint - ergo, cure time. The elastomer hardens under pressuer and compresses ~12%. YOu should install the sofshoe and leave in compressed state for a number of hours (min 3) and finialize the alignment process. Then re-check 3 days later and adjust as necessary.
Costly critical machine: measure and mill a wedge shim if you need something immediately. Sometimes you can't wait on cure time. Cordially, Sam Pickens pdmsampickens@gmail.com |
Thanks guys, I know that the cure time (approx. 2 weeks)is one of the "con's" however, I remember reading that it doesn't prevent you from starting the equipment. Do you know if everything is a waste when the equipment is stated for testing before the "cure time"?
Thanks Manny K |
You don't have to let the equipment set before you start it. But it may be 2 weeks before you see the reduction in vibration.
We had one case (our closed loop #13 motor) where we initially saw no improvement. Then our next check 2 weeks later the 2*LF had dropped to half and it stayed there. In most other cases we saw an immediate improvement. |
