To all,
How close to critical speed can be run without exicting resonance? Is it 10%?
Thanks in advance
Posts: 8 | Location: Hill Air Force Base, utah | Registered: 07 March 2005Reply With QuoteEdit or Delete MessageReport This Post
Difficult to answer without knowing all modal properties. Damping controls amplitude levels at/near resonance.
I believe there are "guidelines" you can use depending on type of machine. Manufacturer should be able to help. As a minimum, acquire data as function of speed.
Take a look here:
http://www.eng-tips.com/viewthread.cfm?qid=160351
Interesting that some references require more % margin if operating just above critical speed than just below. Does anyone know why that is? Maybe they are expecting the stiffness may decrease over time?
Moejoe
The safe academic limits is 30%.
If less greater sensibility to unbalance up.
Ricardo Góz from Brazil
Posts: 32 | Location: MG Brazil | Registered: 21 February 2005Reply With QuoteEdit or Delete MessageReport This Post
