Dear all,
Our old model iotech zonicbook DSP interface card was defective, have some body can help us how and where can buy the new one since the iotech give us a crazy price....
thanks and regards,
kk
Posts: 21 | Location: Hong Kong | Registered: 10 March 2005Reply With QuoteEdit or Delete MessageReport This Post
Try Ebay...
Posts: 10 | Location: Uruguay | Registered: 08 March 2005Reply With QuoteEdit or Delete MessageReport This Post
Our card failed also... could not find a replacement, ended up buying a new Zonic with the eithernet interface.
Posts: 78 | Location: Arkansas | Registered: 14 July 2004Reply With QuoteEdit or Delete MessageReport This Post
I experienced this same problem when I moved from a Windows 95 PC to a Windows XP system. I found the company who made the cards in West Chester, PA and visited them. The cards are long out of production, but they made it work!!!! The problem is the voltage out of the card, thru it's bus, into the Workbook. The old computers used to put 12 volts out. The new computers only put out 3 volts! For some reason, the Zonic front end looks for this 12 volts. They opened the DSP and wired in a jumper and it works! The pictures of the fix are included. If your card doesn't work on an old PC (six years old), then maybe the card is truly bad. I don't know if the manufacturer's will work on it (all of the components are too old). The attached picture shows where one end of the jumper goes. I will send a second reply with the other end. Basically, this puts more voltage on the connector to the Zonic front end and it works!
Posts: 216 | Location: Philadelphia,PA | Registered: 18 July 2006Reply With QuoteEdit or Delete MessageReport This Post
Other end of the jumper. Good Luck. If you still need a card, I think I know where I can get one for a price.
