Key point of phase behavior at unbalance|
I quote TA:
"Key point of phase behavior at unbalance:Whatever is the phase difference bertween the OB and IB bearings horizontal phase measurement on a rotor, the vertical difference between OB and IB bearings must be the same (within +/-30*)". I believe this is insufficient. What is missing here is a requirement that on the top of that the phase difference between H and V on EACH of the bearings should be close to 90* if unbalance is the predominant problem. Failure to meet this requirement indicates that other factors such as misalignment, looseness may be a significant part of the problem. Any other opinions? |
David,
You may also need to take into account the type of rotor you are looking at. For instance if it is an overhung rotor. Live Free Or Die |
