Bently Nevada Snapshot|
Hi
Can anyone help? We have 2 Snapshots, someone has lost the handbooks, so no one knows how to use it fully and aparently, the computer with the software on was scrapped!!! Has someone got a copy of the handbook and/or the software. Have contacted Bently, but could not believe the amount of money they wanted! |
Find a stone crusher and throw the snapshots in
Regards, Erik Concha erik.a.concha at shell dot com |
Thanks Erik
Are they really that bad? Phil |
Phil, the analyzer will do the job if all you need are some "on the spot" readings but if you intend to start a condition monitoring program there are other alternatives to better suit you needs.
For the record: We have about 60+ machines on system 1 with 3500 racks and I believe they are the best at online condition monitoring using proximity probes. On the othe hand, The periodic hand held analyzer used with System 1 leaves alot to desire. I tried to set up a walk around program at our refinery and the snapshot was not going to work so I traded them in for one of the competitor analyzers, which is designed for large plant general pupose machinery. Just my opinion. Regards, Erik Concha erik.a.concha at shell dot com |
Phil,
Please refer the Help Menu in the snapshot also check the system1 software. My opinion: Snapshot is also one of the good tool if you know how to apply that. |
Thanks KJAP
I have been onsite hence the delay in the reply, I will have a look at the help menu again. Phil |
get machine analyst by skf..much better i presume
mac |
Thanks macis
But have replaced with Datastick VSA-1215's far easier to use, than anything else we tried. Phil the brit |
