Does anyone know of a good source for drive belts for horizontal balancing machines?
Your input would be much appreciated.
Michel
Michel
Posts: 46 | Location: Illinois | Registered: 04 March 2005Reply With QuoteEdit or Delete MessageReport This Post
We use a local vendor called rubber specialties. We specify the length and they make them. And they are a lot cheaper than IRD, which is the type balance machine we use. I would think any place that makes hoses and belts would be a good place to look.
Ronnie
Posts: 392 | Location: Mobile, AL | Registered: 13 April 2004Reply With QuoteEdit or Delete MessageReport This Post
I use very good polyamide belts for our B-200 Entekird balancing machine. Look at the site to contact a supplier.
http://www.habasitusa.com/
Posts: 65 | Location: Quebec, Canada | Registered: 24 February 2005Reply With QuoteEdit or Delete MessageReport This Post
Great feed back on these balancing machine drive delts. They are designed for low noise, high efficiency and energy saving power transmission independent of pulley diameter.
visit
http://www.balancingweights.com/Accessories_for_Balancing_Correction_Weights_Application.htm
Then scroll to the bottom of the page
Distributed and recommended by such companies as The Balancing Systems Group. In my opinion one of the "guru" companies in the balancing industry.
Posts: 7 | Location: Clarence, NY | Registered: 11 March 2005Reply With QuoteEdit or Delete MessageReport This Post
Thanks for your help guys...
We all wear so many hats...
Normally I'm a vibration analyst and sometimes a field balancer, alignment guy, or grease monkey.
Apparently in this case I was the expeditor of parts.
Oh well, such is life in small business...
Again, thanks for all your help!
Michel
