I'm looking for something to mount on the motors and gearboxes for the Acc. to mount to.
Need your help what do you guy use and what kind of glue is used. I have tryed but not happy with what I have used.
Mr. Greg
Posts: 2 | Location: Northwest US | Registered: 13 May 2008Reply With QuoteEdit or Delete MessageReport This Post
Mr. Greg
I have had good luck with the epoxy on this page. You just have to make sure the surface is clean and you get the glue mixed well. We have 100s of points in place using this. http://www.stiweb.com/proddata/cmcp200series.htm#Acrylic%20Adhesive%20Bypacs:
This message has been edited. Last edited by: ddane,
Posts: 65 | Location: Fort Worth Texas | Registered: 02 December 2006Reply With QuoteEdit or Delete MessageReport This Post
What epoxy did you use? And what about the mounting points were do I get them? Can I use flat washers?
I'm looking for a low cost way of adding points.
Mr. Greg
Flat washers will work, IF they are flat (most aren't since they are stamped). I like Loctite Depend adhesive. Needs to be "fresh" though. You could use a "spot face" tool (get it from CTC) and simply machine a spot face at each point. The pilot bit will leave a slight (around 1/16") dimple though. Not a problem if the casing/casting is thick enough.
Link to end mills, epoxy and permanent mounting pads for accelerometers:
http://www.reliabilitydirectstore.com/Mounting-Accelerometers-s/248.htm
Posts: 49 | Location: Dubai | Registered: 16 August 2006Reply With QuoteEdit or Delete MessageReport This Post
Also this! Studs are about $3 made on CNC, Transducers SUPPLIED have Quick Fit base attached!
FYI
I used these, however large customers manufactured their own studs, similar pricing!
W
The washers should be flat just like the earth. That could be another post.
Bill
Bill.Foiles@bp.com
By the same logic, the magnets should be rare, like the earth.
Although the earth is also 2-poled. Confused
