Bearing Frequencies|
I've got a TIMKEN 15716 797 DE (stamped on the bearing) which doesn't exist in my database. I would appreciate any help with this. Thanks.
BEARING FREQUENCIES FOR Tim 15716
********************************* PHYSICAL DATA ------------- Number of Balls/Rollers : 15 Ball/Roller Diameter : 1.1250 Pitch Diameter of Races : 6.100 Contact Angle (Degrees) : 40.0 Inner Race Rotating : Yes SHAFT TRAIN SPIN OUTER INNER HARMONICS SPEED (FTF) (BSF) (BPFO) (BPFI) --------- ----- ----- ----- ------ ------ 1 1.00 .429 2.66 6.44 8.56 2 2.00 .859 5.31 12.88 17.12 3 3.00 1.288 7.97 19.32 25.68 4 4.00 1.717 10.63 25.76 34.24 BALL/ROLLER SPIN (BSF) INNER RACE PASS (BPFI) HARMONICS PLUS 1xFTF SIDEBANDS PLUS 1xRPM SIDEBANDS --------- ---------------------- ---------------------- 1 2.66 8.56 2.23 3.09 7.56 9.56 1.80 3.52 6.56 10.56 2 5.31 17.12 4.88 5.74 16.12 18.12 4.46 6.17 15.12 19.12 3 7.97 25.68 7.54 8.40 24.68 26.68 7.11 8.83 23.68 27.68 4 10.63 34.24 10.20 11.06 33.24 35.24 9.77 11.49 32.24 36.24 -------------------------------------------------------------------- Frequencies in Hz Cordially, Sam Pickens pdmsampickens@gmail.com |
Sam,
Where did you get that information? Timken's website and their catalogs do not list that bearing. Danny |
Thanks Sam. I'm curious too, I checked the web and couldn't find it. Maybe I didn't look hard enough??
try this :
direct industry |
THE BEARING EXPERT |
| <Don N>
Here is the link for the bearing frequency calculator on the Timken Site.
http://www.timken.com/timken_ols/bearings/GST/WEB_gst/GST_BrgPeriodicFrq.asp |
Thanks Don. I did manage to find that calculator. The problem was that the part number "15716" is not recognized and a search on the site didn't come up with anything either. Can parameters such as "*" or "/" be used for searching there?
