Machines are a little like people in that no two are exactly alike. Some machines are "noisy" all the time. Others deteriorate in a nice, predictable fashion. I can walk up to most machines I've never seen before and make a call on it with about an 80% gut-feeling confidence level. But that requires more than just collecting a spectrum/waveform... I also check temperatures, run my hand around the machine, listen to it with headphones, listen to it with a yellow-handled-analyzer, etc. But to be really be sure (say 95% confident), I need trend data. I wouldn't even consider trying to do "condition monitoring" without trend data. It might be possible, but I wouldn't associate my name with such a system.
| Posts: 1282 | Location: Arkansas | Registered: 20 February 2005 |    |
I like trending on contineously monitored machines; normal route monitored machines and the trend isn't so great in my opinion. I'm using a CSI 2120 in a metals plant is trending is almost useless on regular routes. But is a tool none-the-less and useful at times. Where does the machine fail; that is everything. But I see tending all over the planet. I like spectral analyses along w/TWF.
Cordially, Sam Pickens pdmsampickens@gmail.com
| Posts: 1698 | Location: Eastern USA | Registered: 04 August 2004 |    |
I think OA meters are widely used and you can easily log and track the OA level reading and perform math on it basically better than any data collector I've seen as they don't do the curves generally or curve fitting to reality; only linear curves as a rule or mean taken. So if trending were adequate, we'd be looking for a job.
RBMware 4.9v I believe and yes it presents a tend but isn't worth a whole lot. Full time monitoring trends are very good I think but route trends or 5 sec/mo is lacking. So my unit shows Pos AH up, Pos AV down and maybe BH up; who knows what it'll be next.
Sam, how many 100's of examples would you like to see of how well monthly trend data works (taken with a 2120 and MasterTrend)?  Most machines trend very well, drawing a flat-then-exponential curve with the 'trigger' being a sharp upswing in several parameters.
