hello
how can help in how can i introduce the phase measurement to the database and meaure it bye using emonitor odyssy sodtwate -workstation and enpac 2500 data collector
thank you
eng.ahmad
Easy,
Set up Mag reading in Measurement pane. Select collection specification Mag/Phase.
Posts: 49 | Location: Dubai | Registered: 16 August 2006Reply With QuoteEdit or Delete MessageReport This Post
And hope you don't get the message "1 point not loaded due to unsupported function". Roll Eyes Mad
That's the message you'll get on the newest op system. Hope they correct it before it goes to distribution.
Posts: 772 | Location: Marietta, Oh | Registered: 15 April 2004Reply With QuoteEdit or Delete MessageReport This Post
Hello DEAR FRIENDS Wyane A and PRS_Dave
Thank you very much about your help i did not get the message (not loaded due to unsupport)
and i will try to find Mag reading set up
Tank you and best regards
eng.ahmad
If you haven't found the mag reading setup yet, then you don't know whether or not you will get the "unsupported function" message. It will only appear when you try to load the EP.
Unsupported Function occurs when one parameter in the measurement definition pane is not supported by the data collector.
Ensure filter is set to 1st Order.
WA
Ah Wayne,
I do believe you are right. I forgot about that filter having to be at first order. Frowner
Thanks for reminding me. I will try that myself again Roll Eyes
Yes Wayne,
I believe I now remember that filter having to be at first order. That is probably what I have wrong.
HELLO
Thank you Mrs Wayne and Dave about your help i tried today the measurement pane and i couldent find what you said, i will try to set the filter at first order, but where in the in data histry window or whrere?
thank ypu agin and iam sory
eng.ahmad
It is located in the collection specification for that magnitude point.The easiest thing to do is create a collection spec and call it Phase. Then when you want to include phase for a particular machine or point, you can use that collection spec.
If you don't understand what I'm talking about, you need to get some one on one training on Odyssey. Wink
Dear Mr PRS_Dave
THANK YOU VERY MUCH REALY ABOUT YOUR HELPING AND INTERSTING IN MY QUESTIONS.
I understand what you asked, i will do a collection for phase.
But i have a question :
There are no phase units (degrees, radians,or degree 360) in the data type in the data history window while i build my database how can i activate these units?.
thank you
best regards
eng.ahmad
The column will appear when you actually collect the data. When you click on the magnitude reading that includes the phase collection spec, the value will appear in the data history window under the "Phase" column.
This message has been edited. Last edited by: RRS_Dave,
Ahmed,
Phase column is always available when using Magnitude data history pane.
To change phase units go to SETUP>OPTIONS>GENERAL database, to configure.
WayneA
Dear sirs
thank you very much
I see the phase value while i taking the measurement in the data collector, but the phase value not appear in the phase column
thanks
eng.ahmad
You stored the reading in the Enpac didn't you?
Hi
How are you
Can i know from where are you Mr PRS_Dave and Mr wayne A
thank you very much about ur helps you are realy experts
thank you
eng.ahmad
I work for major pump manufacturer Dubai/Abu Dhabi/Khober.
20 Yrs CBM.
Wayne A
Eng. Ahmed - I assume you are based ME region?
We (my company)are not a product vendor, just a service company.
Several Seminars are coming to Dubai/Abu Dhabi 2007. I suggest you use search (engine) to meet and communicate with experts in CBM field for the ME region. Maintenance Management and Rotate are annual conferences. All vendors are welcome? Look forward to seeing you all. Many other conferences are available through different (seminar provider)companies and vendor in the ME region.
hello
thank you Mr wayne A, the conferences are very helpful and give many benifits but its very costly to come and share in my account
thank you
eng.ahmad
[QUOTE]Originally posted by Wayne A:
hello Mr wayne
can you explain why we use 1St order filter when we want to measure phase?
thank you
eng.ahmad
