In CSI RBM ware database set up inside "Tree structure" under the selection "Sensor/ Signal Info" there is an option " Integration mode over ride" were there is three selections. Digital, Analog and none. Can anybody explain which is the normal selection and what does it indicate.
Posts: 6 | Location: UAE | Registered: 28 June 2005Reply With QuoteEdit or Delete MessageReport This Post
abdulla,
I may be wrong but I'll give it a shot. I believe the over ride changes the settings in the analyzer. Your normal analyzer settings for overall level mode and signal integration mode can be set to either analog or digital. Mine is set to overall level mode "digital" and signal integr mode "analog". I was told that the signal integration should be analog as to not digitize the waveform. I have the over ride set to "none".
Like I said, I may be wrong and someone may be able to clarify this but I think thats how it works.
Froto
Posts: 60 | Location: eastern USA | Registered: 13 April 2004Reply With QuoteEdit or Delete MessageReport This Post
