Peoples.
I trying to find for sensitivity of vibration sensor ENTEK IRD 195I SN6087 ICP.(..?...mV/G).
I have been searching for it's specification by Google until now I have't got any thing.
Dose anyone using this sensor or know where I can found the specification of this sensor.
Thanks, have a nice day..
Phoo
Posts: 78 | Location: Eastern | Registered: 03 August 2005Reply With QuoteEdit or Delete MessageReport This Post
I haven't used one in 4 years now; but recall it's a 100 mV/g transducer. I'm 97% sure. It's easy to find out - use it and hopefully that's not the only transducer you have - compare it. But a stand-alone reading should make sense as basically all will fall into 0.1 V or 0.5 V or 1.0 V.
Phoo,
If in fact it is a 195-I (pn 39497), then it is a 500 mv/g; Low frequency; low bias; ICP Power
It was used with the old smart meter (TEC'S before IRD bought them).
The freq range is (+/- 5%) 30 - 120,000 cpm
(+/- 3 db) 12 - 360,000 cpm
Res. Freq. 10 kHz
It has a long settling time (about a minute, which is surprising for a ceramic shear mode.
The bias voltage is 6 to 8 volts
Hope this helps. Shoot, hope it's for the right transducer. They came with a square magnet I think.
The old model 196-I was the 100 mv one.
Dae
