Had the need to modify mpm (meter/minute) to rpm factor (for a set of like rolls) but found in Dbaseutility that under " action field " there was only the option fpm (feet/minute) to rpm factor but not the one in metric units.
This comes despite the fact that database in global information is defined as metric, and in Dbase set-up the speed type code is mpm. Spectra are saved in mpm units also.
Doing some trials I realized that in order for the factor to be modified as required I needed to divide it by 3.28 (not surprisingly that's the conversion factor between meters and feet). Problem was solved this way but wonder where in RBMware a set up is to be changed so that in DbaseUtility under the "action field" mpm to rpm factor is one option for those who have their databases using the metric system.
Posts: 23 | Location: Switzerland | Registered: 20 February 2005Reply With QuoteEdit or Delete MessageReport This Post
That sounds like you need to contact CSI and let them decide to take care of it or not.
Mick McAfee
Mick McAfee
Posts: 65 | Location: Kalamazoo, MI | Registered: 07 February 2006Reply With QuoteEdit or Delete MessageReport This Post
