qualifications for IR|
What would be considered the minimum qualifications to perform route based IR Thermography?
Thanks, Danny |
For the person or the equipment? I'll assume the person for now.
Like the other technologies, if you are starting from scratch then at least a Level I class to get accustomed to the terms, equipment and limitations of IR. Route-based mechanical or electrical? If you know what makes the equipment tick, you'll have a better understanding of what the source of the problem may be. You'll also be more aware of the safety aspects. I'm not an electrical guy. I know enough to know when to ask for help. Will the person just be collecting data or doing the analysis as well? You start venturing into Level II areas then. I know we've talked about certifications in the past, but at least you know what they should be able to do. Patrick |
I would recommend Level II. Additionally, electrical safety training, for electrical routes, and related OSHA training for mechanical systems.
Additionally, I have made MIL-STD-2194 "Infrared Survey Procedure for Electrical Equipment" available to download from http://www.motordiagnostics.com/Presentations.htm under the fourth item: T-Solutions 2005 Tech Papers. Hope this helps. Howard Howard W Penrose, Ph.D., CMRP President, SUCCESS by DESIGN Reliability Services Author: "Physical Asset Management for the Executive (Caution: Don't Read this on an Airplane)" and; "Electrical Motor Diagnostics: 2nd Edition" |
European Norm 473:
For taking pictures Level I certification. For analysis and rating Level II |
Thanks for the replies.
This is about what I had expected and the same as in vibration analysis. Level 1 to collect data, Level 2 to analyze. Howard, Thanks for the links to your site. Very helpful information. Regards, Danny |
