Folks
one more curious question.
Are all IR-camera manufacture has caliblate the camera with black body. What can use instead of black body.
Cheers.
Phoo
Posts: 78 | Location: Eastern | Registered: 03 August 2005Reply With QuoteEdit or Delete MessageReport This Post
Generally one thing constitutes a standard, not many. Why do you need a white horse if the black one is OK, paid-for, reliable, etc... Why is it called a 'standard'?
Sam
Posts: 1513 | Location: Eastern USA | Registered: 04 August 2004Reply With QuoteEdit or Delete MessageReport This Post
Sam
I just want to know any thing else manufature use for caliblate of IR-Camera. Smiler
Have a nice day
Phoo
I think you can use other source of heat that you know the temperature of its.The second use the tear ducts to recheck your IR camera.
Posts: 10 | Location: CHONBURI | Registered: 29 March 2005Reply With QuoteEdit or Delete MessageReport This Post
The issues with measuring a low emissivity surface are: it does not emit much of its own radiation, it reflects the surroundings, a small absolute change in the emissivity (say 0.01) becomes significant when compared to the already low emissivity (say 0.1 to 0.05) of the surface.
As electricpete suggests, cavity and coatings can help. However, see this weeks tip (mine Wink) on irinfo.org about the unintended consequences of altering the emissivity of the surface.
If the aluminum is hot AND you can control the background to a low and uniform temperature, then you MAY be able to get an acceptable measurement. You have to examine that from the equations describing the radiation leaving the surface.
HTH,
Jack
Jack M. Kleinfeld, P.E.
Kleinfeld Technical Services, Inc.
Infrared Thermography, Finite Element Analysis, Process Engineering
Bronx, NY 10463
718-884-6644
866-884-6644 toll free
212-214-0919 fax and voice mail
Skype: JKEngineer
JKEngineer@aol.com or JKEngineer@KleinfeldTechnical.com
come see what we can do for you: http://www.KleinfeldTechnical.com
Posts: 22 | Location: Bronx NY | Registered: 16 April 2004Reply With QuoteEdit or Delete MessageReport This Post
