Hi
I need to know, at what temperature is a thermographic image too hot and requires you to stop machine and repair immediately for the following:
1) Neutral wiring connector block
2) Fast contactor
Also if the target distance of the image changes, what effect does it have on the spot temperature?
Thanks for your help in advance.
Posts: 20 | Location: Nothern Region | Registered: 20 May 2005Reply With QuoteEdit or Delete MessageReport This Post
If you are asking yourself, "How hot is too hot?" then you either need a simular component for a comparison or you need some baseline data.
As the distance from the target increases the atmosphere absorbs more of the exitant infrared from the target and it emits its own infrared, adusting the distance, relitave humidity and air temperature settings in your camera will correct for this. However changing these settings will not help with spot size issues and if you are too far away from the target you will not be able to measure it accurately. You can only correct for this by moving closer or using external optics.
Bob Berry
Thermal Vision
8 Old Fair Green
Dunboyne
Co Meath
Ireland
Posts: 78 | Location: Ireland | Registered: 08 June 2005Reply With QuoteEdit or Delete MessageReport This Post
