Hi all, I need help to find the SKF equivalence for a ball bearing with AFBMA # 75BC03J3. Thank you all.
Posts: 1 | Location: Argentina | Registered: 22 February 2007Reply With QuoteEdit or Delete MessageReport This Post
Walter,
The number listed is for a 6315 C3 deep groove single row ball bearing. Take the first 2 numerals divide by 5 gives the bearing size, BC is for ball bearing, conrad style. The 03 indicates it is a 300 medium series.
Hope this helps,
Gary B
Posts: 114 | Location: Palatka, FL | Registered: 04 August 2005Reply With QuoteEdit or Delete MessageReport This Post
Dear Gary B
u have asined bearing no 6315C3 against 75BC03J3. It is not matched with CSI Warehouse which has 100000 bearings of different companies
I am using 2130 analyser of CSI
faisal
Posts: 14 | Location: Khaskheli | Registered: 25 February 2007Reply With QuoteEdit or Delete MessageReport This Post
There is a frequency calculator at www.skf.com. Look in upper half of your screen about center of the page for "Calculations" then scroll down to frequency calculator. You may also have to dig a bit for dimensions to input into the calculator.
John from PA.
Posts: 363 | Location: Exton PA | Registered: 22 February 2005Reply With QuoteEdit or Delete MessageReport This Post
Try 6315 in the CSI Warehouse... also see Converting AFBMA Numbers
Or order SKF Pub. 140-430 June 2000
