Hi,
I need the acceptable limits of Viscosity and Flash points for the following lubes - used oils
ESSO LUBE D3-10 - Application - Engine oil
SAE 15W/40 - Application - Engine
Ramesh
Posts: 31 | Location: Abu Dhabi | Registered: 05 August 2006Reply With QuoteEdit or Delete MessageReport This Post
Flash point may vary with comtaminate. Try exxon.com or your oil supplier. Application needs to be known.
Posts: 1614 | Location: Eastern USA | Registered: 04 August 2004Reply With QuoteEdit or Delete MessageReport This Post
You can check your local specs of your engine oil the flash point and viscosity is provided there Im sure.
Here's the baseline :
Flashpoint should not be lower than 400 deg fah,
the higher your flash point the better, if this is engine oil remember that at 300 deg Fah normal range of temperature there are already oil evaporating from the system.
Viscosity have a range of + or - 10 change in the original specs.
Rolly Angeles
Teacher
www.rsareliability.com
