Dear
Can anyone post the ASTM Standards (with procedure) for Lube oil analysis
Thx
Posts: 3 | Location: Saudi Arabia | Registered: 30 October 2006Reply With QuoteEdit or Delete MessageReport This Post
There are so many of them for separate tests. For turbine oil, there is one good one. If you search internet, you will find it.
Anyway, what type of oil analysis are you interested in? Laboratory or onsite tests?
For onsite tests, don't really need standards because the toolkit has been designed to it.
Thx jose....
I need the procedure for the following standards done in lab
ASTM d-893 - for Insolubles, pentane in Vol%
ASTM D-974 - for Acid number in mg KOH/g
ASTM D-445 - Viscosity @ 40 C in cSt
ASTM D-1533 - Water by karl Fischer in ppm
Actually i received the results for Lube oil sample from lab, mentioned according to ASTM Standards
But i need to know for the above tests what is the acceptable limit.
I'm not sure whether thoese standrds contain the tolerances. If yes, you have to buy them eg from www.ihserc.com. However, searching noria.com will give these ranges.
Btw, haven't you attended any oil analysis or lubrication course?
How long have you been involved in oil analysis?
If you work at an oil lab, there are a ton of ASTM standards that would be relevant for you.
If (like me) you work at a facility which has rotating equipment and sends their samples out for analysis, there is only one ASTM standard I know of that is very relevant.
ASTM D-6224 "Standard Practice for In-Service Monitoring of Lubricating Oil for Auxiliary Power Plant Equipment"
It includes a summary of the various available tests, reference to relevant standards, recommended frequencies and limits.
Thanks josh , electricpete...
Am like pete. Sending samples outside and get the results. Sometimes they say ok and sometimes not ok based on ASTM standards..Thats why i asked for any limits to co-relate with the lab results.
Pete..if u dont mind can i get the standard ASTM D-6224, if u hav soft copy...
Thanks again
pete
sir can u send me also the soft copy of ASTM D 6224. thanks in advance.
ianski.
Posts: 15 | Location: metro manila | Registered: 28 February 2005Reply With QuoteEdit or Delete MessageReport This Post
Electricpete, what is the difference of ASTM D-6224 to the following article? Do you have any article on ASTM 6224?
http://www.practicingoilanalysis.com/article_detail.asp...edbookgroup=PowerGen
Ok Electric pete, I founf the difference as follows:
ASTM D 6224 Document Information:
Title
ASTM International
Publication Date:
Nov 10, 2002
Scope:
This practice covers the requirements for the effective monitoring of mineral oil and phosphate ester fluid lubricating oils in service auxiliary (non-turbine) equipment used for power generation. Auxiliary equipment covered includes gears, hydraulic systems, diesel engines, pumps, compressors, and electrohydraulic control (EHC) systems. It includes sampling and testing schedules and recommended action steps, as well as information on how oils degrade.
NOTE 1 - Other types of synthetic lubricants are sometimes used but are not addressed in this practice because they represent only a small fraction of the fluids in use. Users of these fluids should consult the manufacturer to determine recommended monitoring practices.
This practice does not cover the monitoring of lubricating oil for steam and gas turbines. Rather, it is intended to complement Practice D 4378.
The values stated in SI units are to be regarded as the standard.
This standard does not purport to address all of the safety concerns, if any, associated with use. It is the responsibility of the user of this standard to establish appropriate safety and health practices and determine the applicability of regulatory limitations prior to use.
ASTM D 4378
2003-MAY-10 • Active/Current •
Standard Practice for In-Service Monitoring of Mineral Turbine Oils for Steam and Gas Turbines
Add to Wish List Hardcopy:
$44.00 Add to Cart
Electronic:
$40.00 Add to Cart
Description:
This practice covers the requirements for the effective monitoring of mineral turbine oils in service in steam and gas turbines, as individual or combined cycle turbines, used for power generation. This practice includes sampling and testing schedules to validate the condition of the lubricant through its life cycle and by ensuring required improvements to bring the present condition of the lubricant within the acceptable targets.
This standard does not purport to address all of the safety concerns, if any, associated with its use. It is the responsibility of the user of this standard to establish appropriate safety and health practices and determine the applicability of regulatory limitations prior to use.
