I got an interesting email from David Gleason following up on conference he had presented at.
One of the messages offered was my "Inverse-Square Rule for Deferred Maintenance" which states: "If a part is known to be failing but left in service until the next level of failure, the resultant expense will be the square of the primary failure part."
Working in focus groups representing each type of industrial maintenance, they tested this rule by completing my "Inverse-Square Rule for Deferred Maintenance" Worksheets (attached below this post) to identify and total all costs associated with their breakdown events. In every case and industry, when they totaled the direct maintenance, indirect, and intangible costs and took the square-root, the value was equal to the cost of the primary failure part, or the cost of the deferred inspection, or the cost to train the employee that would have avoided the exponential cascade of expenses. This rule seems to apply across all types and scales of maintenance. They then computed their True Risk/Reward Ratio for Deferred Maintenance.
These people now have a very powerful tool to better manage the function of maintenance in their organizations because this rule is an accurate predictor of costs and man/hours that can be applied in the field. When facing an operational or budgetary maintenance decision, all they have to do is square the cost of the primary part that needs to be replaced or multiply the early intervention Work Order cost by the Risk/Reward Ratio for their industry to produce the numbers necessary to make the right decision.
David Geaslin, Principal
The Geaslin Group
Web: www.geaslin.com
Web: www.ManagingMaintenance.com
If you download it - I would appreciate your comments posted here.
Thanks.
Terry O
Excel SpreadsheetInv-Sq_Maint_Worksheet1.xls (36 KB, 25 downloads) Inverse-Square Rule for Deferred Maintenance Worksheets (Excel)
Posts: 890 | Location: Southwest Florida Gulf | Registered: 03 April 2004Reply With QuoteReport This Post
Is it not a subjective calculation?
Posts: 2889 | Location: Borneo | Registered: 13 February 2005Reply With QuoteReport This Post
Mr. Geaslin has been proposing this relationship for some time, well over a year, and according to other things I've read he had data that supported it from a particular industry.
I'm sure Terry is looking to see if this relationship is applicable over a range of industries.
Posts: 67 | Location: Knoxville Tennessee | Registered: 24 February 2006Reply With QuoteReport This Post
If the part falling is (for example) installed at an air compressor, or a boiler, or a fan...
what difference it makes if the equipment is at an electronics assembly plant, at an injection molding facility, or at a pharmaceutical drugs manufacturing site?
Darth Eugene Vader
Posts: 1044 | Location: Puerto Rico, USA | Registered: 28 October 2005Reply With QuoteReport This Post
The only difference is the environment Big Grin
Idled workers? Hm.. not at maintenance, according to the signs, we are short on manpower Big Grin
Posts: 871 | Location: Suriname | Registered: 16 June 2004Reply With QuoteReport This Post
Well, I was intentionally vague in my last post about the industry. If I told you that this information was based on only real estate you and possibly your company would discount the information, saying it doesn't really apply to manufacturing industry. Wouldn't you.
The study was based on a specialized industry, but not real estate.
If the item under investigation is the governor of a gas turbine used for power generation supplying part of the nation, its impact is higher than the wheel of trolley used to carry bricks at a construction site Big Grin
Well, let's see his examples then and the crowd here will try to prove it's wrong or provide exceptions or limitations or qualification to the inverse square rule (a standard scientific method or peer review?).
  Powered by Social Strata
