If someone asked you question saying what basic maitenance activities are? What will be your response
Posts: 12 | Location: Rosslyn, Pretoria | Registered: 14 March 2008Reply With QuoteEdit or Delete MessageReport This Post
To start:
1. Clean
2. Visual Inspection
3. Lubricate
4. Adjust (bolts/nuts tightment, belt tension)
5. Replace worn parts, filters, etc.
Visual Inspection may be done concurrently with other tasks. Inspect as you clean, notice worn or loose parts while you remove dust, read oil level as you wipe sight glass, etc.
Darth Eugene Vader
Hi,
Basic maintenance covers like
*Checking lube oil level
*Monitoring Temperature
*Observing Noise
*Confirm integrity
Posts: 4 | Location: Qatar Offshore | Registered: 25 October 2007Reply With QuoteEdit or Delete MessageReport This Post
Vee
Giga,
Keeping equipment
1. Dry
2. Clean
3. Lubricated (proper grade, quantity and water free)
4. With bolts tight
5. Properly aligned
6. Properly balanced
lays the foundation for operating them reliably. Without these in place, efforts on applying e.g., RCM, will be a waste.
V.Narayan (Vee)
Vee
Giga,
There are also basic Operating activities, falling generally in the category of "Tender Loving Care". TLC includes the following:
1. Starting and stopping equipment with care, per OEM instructions.
2. Flooding or Venting equipment at start, as per OEM.
3. Loading the equipment gently, ramping up as it 'warms up'.
4. Unloading equipment gently, ramping it down before stopping it.
5. Keeping equipment under steady conditions as far as possible - Tramline operations
Some of the 'maintenance' activities listed in my earlier post are usually done by Operators, but they remain maintenance acticities irrespective of who does them.
Together the two sets contribute greatly to keep relaibility at high levels.
V.Narayan (Vee)
Since question covers broad area , your answer also shall be
"Any Activity which preserve the Function of the equipment "
Posts: 35 | Location: qatar | Registered: 18 August 2006Reply With QuoteEdit or Delete MessageReport This Post
