GCV
Friends,
Please suggest the reliability improvement tips for Air conditioning unit (Window AC).
Posts: 9 | Location: India | Registered: 19 January 2007Reply With QuoteEdit or Delete MessageReport This Post
If you tell your problems, maybe the forum memebers will try to suggest something. Otherwise buy a book on HVAC on the book.
As in any equipment , follow the manufacturers guidelines on maintenance. If you are just starting a program start with cleaning and visual inspection. Collect data as you go so you have all the information to establish a parts stock for the units. A simple way if you are just starting out is look at your old repair orders for similar failures, then use that as a "check list" when you do a PM. Make a bullet list of items to check based on that history for a pm task, then set the task interval at a level you feel comfortable with. Put the process in place and keep an eye on the results.
Posts: 14 | Location: St Louis | Registered: 31 January 2007Reply With QuoteEdit or Delete MessageReport This Post
