Hello gents,
I've some questions regarding start implementing Kpi's in logistics and mobile equipments maintenance:-
1-How can we measure the standby equipments time?
2-The replacement for one truck caused confusion in MTTR, MTBF & availability?
3-Do any gentleman has a excel sheet as an example for Kpi's with stand by? I appreciate it in a Zip file.
4-Unit of measure is Moment or Hour?
Kind regards,
Haytham Taha.
Performance analyst, cement Co
Haytham Taha
Posts: 7 | Location: assiut | Registered: 27 August 2006Reply With QuoteEdit or Delete MessageReport This Post
Check this out:
http://www.plant-maintenance.com/RCMforME.shtml
Can search internet if you know what you want.
Moment? Like instant or minute?
Is the rate of events so fast that events/hour or events/day are not good enough to measure it?
Darth Eugene Vader
Eugene,
Events/ hour or Days is ok but always we
Say ''start moment'' any way my main concern is an example for it with a standby (.xls) format.
Haytham Taha
Are you asking for a spreadsheet to calculate KPIs for a standby mobile equipment?
Yes josh, prefer to both as an example. (Showing the calculation of standby).
Cause as I knew that we calculated the down time. But do we calculate it if we replace with a standby one?!!
Thanks for your replay.
Haytham Taha
Hello Heposlamos,
For standy you should be using availability in which it will be 100% all the time assuming it aint broke.
For running equipments you should be using both availability and utilization. Your mobile equipment might be available 100% but have been only utilized for 60%
Heres the formula :
Availability = Avail time - All downtime
Available time
Utilization = Loading Time - Machine Downtime
Loading Time
where : Loading time is available time - planned downtime
both utilization and availability will be in percentage
Rolly Angeles
Teacher
www.rsareliability.com
