Hi
Can anyone give me advice on measuring vibration in 'Can' pumps, sealess ones such as HMD. At the moment I just take velocity readings at the motor end. Is there anything that can be measured to monitor the condition of the Mag drive or outer can etc.
regards
Chemic.
Posts: 8 | Location: England | Registered: 26 March 2007Reply With QuoteEdit or Delete MessageReport This Post
You can try to refer to ISO vibration related standard which discuss about measuring vibration on non-rotating parts.
Chemic,
You need to look at a cutaway drawing for the model of interest. For example:
http://www.sundyne.com/cda/ind/pr/cutaway/0,10517,CLI1_...3_IMD2_MDI68,00.html
This model has both antifriction bearing and bushings. You should be measuring vibrations on the pump bearing housing as well as the motor.
