Dear friends,
Please suggest a suitable pressure sensor which can give the pressure reading ( not pressure pulsations) with CSI 2130. Please specify the manufacturer info too.
Sree
Posts: 33 | Location: INDIA | Registered: 30 July 2007Reply With QuoteEdit or Delete MessageReport This Post
Any strain gage type pressure sensor with an analog output can be used provided it meets the pressure range and other process criteria. If the output is a current, then use a resisitor to convert to a DC voltage. The 2130 should be set for a DC-type sensor with appropriate volts per psi or Bar sensitivity.
