This is a data sheet for the equipment in the attachment. CONFIGURATION : 51-K-01 HP.CYCLAR .REC .COM
Number of Shafts: 3
Machine Run Under Load? Yes
Analyze Shafts Independently? No
SHAFT --- COMPONENT TYPE ---- -------- CONNECTION TO OTHER SHAFTS --------
No. AND DECRIPTION SHAFT No. COUPLING TYPE ORIENTATION
1 Turbine 2 Disc/Shim Pack In-Line
Turbine6 0 Unknown Unknown
2 Compressor 1 Disc/Shim Pack In-Line
Compressor2 3 Gear Drive Other
3 Compressor 2 Gear Drive Other
Compressor2 0 Unknown Unknown
POINT ID SHAFT No. POSITION ORIENTATION PROBE TYPE
1 T5B 1 Outboard BRG Radial-X Shaft
2 T5A 1 Outboard BRG Radial-Y Shaft
3 T5C 1 Outboard BRG Radial-X Shaft
4 T5E 1 Inboard BRG Axial Shaft
5 T5F 1 Inboard BRG Axial Shaft
6 C6A 2 Inboard BRG Radial-X Shaft
7 C6B 2 Inboard BRG Radial-Y Shaft
8 C6C 2 Inboard BRG Radial-X Shaft
9 C6D 2 Inboard BRG Radial-Y Shaft
10 C6E 3 Inboard BRG Axial Shaft
11 C6F 3 Inboard BRG Axial Shaft
12 T5D 1 Outboard BRG Axial Shaft
Shaft No. 1 : Turbine Turbine6
Turbine Type: Steam
Rating: 14452. Kilowatts
Number of Blade Rows/Cylinder: 3
Variable Speed? Yes
Cylinder Type: High Pressure
Unit Location: Outdoor
Inboard Supv. Inst. Available: Yes
Outboard Supv. Inst. Available: Yes
Machine Support: Steel Frame
Shaft Orientation: Horizontal
Support Position: Bottom
Inboard Radial Bearing: Sleeve
Lubrication Type: Pressure Feed
Outboard Radial Bearing: Sleeve
Shaft Change Positions (Translate)? No
Shaft No. 2 : Compressor Compressor2
Support Position: Unknown
Shaft No. 3 : Compressor Compressor2
REGARDS
Khalid A. KALFOUT
Rot.Equipment Inspector
( (04)321-8381
mailto:KALFOUTKA@GMAIL.com
Posts: 3 | Location: Kingdom Of S>A -Yanbu | Registered: 17 October 2005Reply With QuoteEdit or Delete MessageReport This Post
For info or question?
Posts: 2528 | Location: Borneo | Registered: 13 February 2005Reply With QuoteEdit or Delete MessageReport This Post
as you like
It is good case to buildup your information and If you have any good soluation post it.
all we need to improv and devlop our crow.
REGARDS
Khalid A. KALFOUT
( (04)321-8381
