We are an independant vibration equipment manufacturer used throughout on all major power plants looking for plant owners that have vibration issues on critical rotating equipment, which can not be solved using periodic vibration tool(s). A plug'n play device capable of seeing what needs to be seen within seconds!
How many different pumps can it continuously monitored at one time ie simultaneously? I think major rotating eqpt in a plant will already be online-monitored in DCS. A gas turbine power plant will also already come with its own online vib monitoring. So only small or medium sized pumps, fans & motors are periodically monitored using a portable hand-held device.
Posts: 2557 | Location: Borneo | Registered: 13 February 2005
Originally posted by Josh: How many different pumps can it continuously monitored at one time ie simultaneously? I think major rotating eqpt in a plant will already be online-monitored in DCS. A gas turbine power plant will also already come with its own online vib monitoring. So only small or medium sized pumps, fans & motors are periodically monitored using a portable hand-held device.
Hello one of our portable units can continuously monitor 4 at the same time. It is great equipment that comes with a person on the other end of the line when you need support! Amazing huh!
KB
Posts: 9 | Location: Glen Allen, VA, USA | Registered: 23 February 2005
We have 4 seawater pumps with one standby unit. Can it also collect running hours for each pump? Can it connected to DCS or LAN for trending purposes? Cona it monitor both the pump & its motor?
Josh, I think what you are looking for is a 16+ channel online survailance system, unless ofcourse you want to add shutdown protection to it. If this is what you are looking for Let me know, I think I might have a few suggestions. ahmeddanish@skfegypt.com
Ahmed H. Danish, CMRP Reliability Consultant Middle East GE Infra, Energy
Posts: 44 | Location: U.A.E. | Registered: 03 January 2006
