Its the fundamental lateral natural freuquency of a beam, built in at one end and free at the other.
Picture a bed so reeds blowing back and forth in the wind. Sometimes used in the description of turbine blades.
I once saw a small hand-held box called a reed vibrometer: this had a glass front and contained about 40 small arms facing the glass. Each arm was 'tuned' to a slightly different frequency, with lowest at the left and getting higher to the right, with the centre arm tuned to 50Hz - by placing the box on a machine you could see the frequencies of vibration that were present. An interesting mechanical gizmo, probably used for electrical work
Posts: 181 | Location: Niue | Registered: 04 May 2005
This term is often used to describe the lateral frequencies of a vertical pumpset. The frequency will be quite low, ie a few Hz to say 10 Hz depending primarily upon the height of the machine. One of the charactereistics of reed-frequency vibration is that it can tolerate a fairly large vibration at the top of the motor without undue distress in the machine. (ie the frame vibration just carries the bearing and shaft along with it).
