Does anyone have any experiance with a bio water treatment system as opposed to a chemical treatment system, Looking to go green and get away from a chemical based system. Looking at 3 cooling towers evaporative each with about 2800 gallons. With chemical system I am still getting a build up of sludge and require to flush out system 18-months to 2 years. ( In Canada still not using metric)
Thanks Glenn
Posts: 10 | Location: Glanbrook | Registered: 30 November 2006Reply With QuoteEdit or Delete MessageReport This Post
What do you use for the bio water treatment system?
Posts: 2520 | Location: Borneo | Registered: 13 February 2005Reply With QuoteEdit or Delete MessageReport This Post
currently not using a Bio system,
Cont. Improv. would be to get in a bio system looking at NEXTEQ,
Problem is any system I have looked at in the past must run 7- 24, and my plant only works 5-24. I do not want to have equipment running if no one is in plant. cool tower water is used to to keep compression presses cool ( heat exchangers) &( water coolers to cool molds)
What are the environmental parameters where the bio system will operate?
Darth Eugene Vader
This is all new to us just in process of getting quotes, and getting a better understanding of the differant systems that are available out on the market.
